Today's install.
View the thread, titled "Today's install." which is posted in UK Plumbers Forums on UK Plumbers Forums.
Whn1
Guess the missing boiler...... 😉 ImageUploadedByTapatalk1361296846.427556.jpg
Hopefully not, there's spacers on the clips and they're spaced apart. Got me worried now 😉
Nice neat job.
If you've used the wee Talon spacers, you'll get foam insulation around the pipework without too many problems. Use tie wraps to bind it nice and tight.
Have to say mate your work is the absolute dogs ********. Teach me please lol
plumbersmate. this ain't rocket science,
first you need teaching, then a g3 cert,
and then do it how you want to see it in your own house,
if your not happy take it out and start again.
forget about the money,a good job is what it is all about.
a nice tidy job, a safe install, and a happy customer,life's sweet.
Nice neat job.
I only started using them about a year ago, make jobs where you have to lag so much easier.
They also save bending crossovers if you use 2 spacers on a clip as the pipe will then pass right over the other one without touching it.
Yea haha it's crossed my mind but I might end up going a bit crazy! Like using 6 stacked up to pass over the pass overs 🙂
well done you are almost good as me 🙂pmsl
You have had lots of time to pull all this bends and how is the insulation going in !?
well done good job
I'm a pro, everything mentioned has been catered for. Even the immersion. I don't think the pictures are doing the spacing justice. 😉
Nice work pal.................. that coil will be a biatch to bleed even on a sealed system, due megaflos coil in coil construction, unless i have missed the AV?
Flue must be close to soffit?
half a mornings worth of work there plenty space to work in unlike the one i done today ,
agree with vern cant see aav nor low level doc??
Was just going to put vent on top of boiler, do megaflow specify otherwise?
flue easily clears gutter/ soffit. The drawing is a rough outline.
We'll see for sure tomorrow, it's changeover day.
Reply to the thread, titled "Today's install." which is posted in UK Plumbers Forums on Plumbers Forums.
Whn1,
Dan,
