I'm a pro, everything mentioned has been catered for. Even the immersion. I don't think the pictures are doing the spacing justice. 😉
nor low level doc??
Nice work pal.................. that coil will be a biatch to bleed even on a sealed system, due megaflos coil in coil construction, unless i have missed the AV?
Flue must be close to soffit?
fair play to you for putting your work on here knowing what this mob is like !!!
Did you wipe your joints off or are they all green today?
