I'm a pro, everything mentioned has been catered for. Even the immersion. I don't think the pictures are doing the spacing justice. 😉
Nice work pal.................. that coil will be a biatch to bleed even on a sealed system, due megaflos coil in coil construction, unless i have missed the AV?
Flue must be close to soffit?
half a mornings worth of work there plenty space to work in unlike the one i done today ,
agree with vern cant see aav nor low level doc??
Was just going to put vent on top of boiler, do megaflow specify otherwise?
flue easily clears gutter/ soffit. The drawing is a rough outline.
We'll see for sure tomorrow, it's changeover day.
fair play to you for putting your work on here knowing what this mob is like !!!
Did you wipe your joints off or are they all green today?
noose.jpg...
Lovely install! Is that an open end left on a gas pipe?!....
And I'd guess at a Worcester ri boiler!
