Toilet bowl and seat problem
View the thread, titled "Toilet bowl and seat problem" which is posted in Boiler Advice Forum on UK Plumbers Forums.
J
jhatter
I have no plumbing experience & I am after your advice and experience please.
I have a toilet seat which is very unstable and keeps slipping at the crucial moment (lets put all jokes to one side for the moment).
Although the seat is securely fixed at the back it still seems very mobile. The problem is that the rim of the toilet bowl is very narrow (an inch at it's narrowest, at the front). Because it is so narrow the pads on the seat are only 1/4 inch away from the edge, so the slightest movement and the seat descends into the bowl area. This is very annoying.
To try and resolve this I have tried different seats and I have attached additional pads onto the underside of the seat, but the problem still occurs.
Unless someone can suggest an alternative, then I think that changing the toilet bowl to one with a thicker rim is the only way to solve the problem.
So my questions are as follows:
1) Can I purchase just the bowl and not a complete toilet suite?
2) How could I pre-check that the new bowl would be compatible with the existing cistern?
3) How long would such a job take a professional, competent plumber?
4) Do you foresee any problems with trying to complete such a job?
Thank you
Yes there is nothing more turdious than a loose wc seat 😀
However when replacing a wc it is a bad idea to change a pan and leave existing cistern and visa versa,the two are made for each other both physicaly and operationaly,you could end up incorrect flush through pan or over spray
A bog standard 🙂)) complete close coupled toilet can be purchased for under £100 so it is not worth messing about with
Ring a plumber explain to him what you have now,what you what to do and he should be able to give you a rough price
Best to ask friends or family and find out if they have a plumber they could recommend
Reply to the thread, titled "Toilet bowl and seat problem" which is posted in Boiler Advice Forum on Plumbers Forums.
jhatter,
Puddle,
