View the thread, titled "toilet cistern" which is posted in Boiler Advice Forum on UK Plumbers Forums.
N
nicole
hi anyone know y my toilet want flush away i just fitted a new pressure fitted cistern and it want even flush toilet paper until third flush
a pneumatic flush valve.
is it emptying the cistern when flushes ?
is it a dual flush or single ?
is this a complete new toilet or just a new valve you have fitted ?
it completly empties and its a single flush cistern complete new system
i've seen this on some of the foreign rubbish we get.
its the design of the pan the water spends half its time running round the rim and has no force behind it to empty the pan.
not much you can do if its emptying it full cistern of water and its filling up to the level.
a lot of them are designed to work together,you therfore sometimes can not fit someone elses cistern to the pan and expect it to work properly
i have been told that the water can be being slowed down too much to take-away the paper if the pipe that runs the water into the toilet bowl is shoved too far into the back of the toilet, the rubber bung can also cause it to slow down if its not correctly inserted
That's only the case for high level and low level cisterns. I think we're talking about closed coupled ones here.
I live in hard water area and the pan inlets get blocked with scale and then the toilet will not flush properly no matter how much water you have to flush with. It just drains away slowly
i just had a back to wall fitted - i believe this would fall into the close coupled catagory ,,am i wrong?😕
Yes that's a closed coupled type as is any WC where the cistern mounts directly onto the pan.
BTW can be low level or close coupled
if the "wall" is a cupboard then it is low level as there is a pipe from the cistern hidden in the cupboard
There are also BTW toilets which are close coupled but I have not seen any with pneumatic flush
mines a BTW in a cupboard with a button flush where air goes out a tube to release the water and the overflow is built into the loo -was from a large diy store with big orange logo adv on telly
sometimes it will take away paper other times it wont but it seems to work better when there is more to take away 😱 if you get my drift!
i have just discovered it has a hairline crack in the pan and its leaking,. could this be interfering with its flush mechanism anyone?
hoping the replacement will be better behaved 🙄
does the water level in pan rise more than normal when flushed some pan cons are very restrictive
no i wouldn't say so it doesnt rise up much higher than a normal toilet.
but sometimes the suction is fairly fast other times the flush /water seems slow... as if not enough air being pulled in
we have concluded there must be a hairline crack in the pan as it is leaking from front and nowhere else- whether this is anything to do with flush performance i dont know...
The pan is BTW the cistern is pneumatic, the cistern is mounted on the wall in the cupboard there is a pipe from the base of the cistern with a bend in it which is connected to the pan using a cone washer.
THIS IS A LOW LEVEL SYSTEM
If the cistern is fitted to the rear of the pan it is a CLOSE COUPLED system
maybe there are some "senior moments" going on is other answers
it wasnt a hairline crack after all just another really bad installation from the guy that presented himself as a plumber, we have since had it re-fitted and bobs your uncle it works fine, this business about it being foreign, too narrow, not enough water etc etc all irrelevant now 😀 i am not a plumber so..😛
Reply to the thread, titled "toilet cistern" which is posted in Boiler Advice Forum on Plumbers Forums.
