Dear Friends
I need to change an inlet valve on a toilet.
At present there is a flexi hose connected to it and there is also an isolation valve so can shut water off.
My question, stupid as it maybe is, the 15mm flexi tap connector fixes to the bottom on the entry valve, so what size is this 1/2"? Also, i take it I need to put a fibre or rubber washer in the tap connector if it hasn't got one?
The Siamp Skipper valve has also broken and so I shall also replace this.
Last question, is it better to replace the coupling kit and large rubber washer each time these are fitted/refitted?
Thank you in advance.
Rocket.
Rocket.
