Toilet help
View the thread, titled "Toilet help" which is posted in Boiler Advice Forum on UK Plumbers Forums.
dalegooderham
hi,
i have been told by my builder that the building inspector has told him that there is no room for a manhole in a garage conversion, he told him that he will need a toilet that you can rod the drain! has anyone got any knowledge of this?
if you need to rod a toilet drain, without removing the toilet, just put the toilet waste into a 4" t instead of an elbow, with a rodding eye on top.
dosnt make sense what youve been told, what are the circumstances ?
shaun
The regs usually work out for an inspector chamber at every change of direction in the drain.
It is a garage conversion to a shower and toilet room, the inspector has said that the builder can not put in an inspection chamber because of space problems, the drain runs the length of the garage and we thought we would be able to insert the chamber.
The inspector has told him that we should put the toilet in with rodding facillities, is the solution then: - we put in a 100mm tee with eye for rodding, would that look intrusive? is there an alternative?
There is no change of direction, just a new pipe (Toilet shower & basin) to join to the existing drain which runs through the garage.
run from the existing drain use a branch to rise to the wc and then a bend to run up to a flush to floor rodding eye which could be extended away from the wc The main thing is that you can rod down to the junction with the existing drain
Reply to the thread, titled "Toilet help" which is posted in Boiler Advice Forum on Plumbers Forums.
dalegooderham,
dalegooderham,
