A
av monkey
Hello guys, could someone give me a bit of advice. Recently found en suite toilet over filling over float over flowing down toilet pan after several hours.
Its filled reasonably quickly and appeared to shut off.
Anyway. Called plumber because wanted it sorted quickly and efficiently.
The house is 10yr old. Has a confeletti pre-set prv under sink. I could not see a isolation valve under toilet and so shut of stopcock. Later realised there is one tucked under cistern.
He turned off isolation valve and turned back on stopcock. After taking of float arm assembly (Torbeck) hoping to replace with the new torbeck assembly found water pressure was now low. 3-4 mins hardly half full.
All he's done is remove float arm assembly leaving body in cistern and operated stopcock and isolation valve. He thinks there may have been some grit stopping shut off torbeck assembly which is now dropped to isolation valve. But will have to remove toilet to get to get to valve and pipes as its not straight up into cistern but in the boxing behind/below pan. We can't understand how it could have change otherwise.
