View the thread, titled "toilet leaking" which is posted in Boiler Advice Forum on UK Plumbers Forums.
My toilet is leaking. After flushing there is water flowing. It is clean water so I wonder what that is. Please, can you advise further?
thanks,
Naveen
So flush pipe does it leak from the cistern or from the connection to the pan
The connection on the pan from the flush pipe
Looks like your going to have to strip it and replace the flush cone
https://www.NoLinkingToThis/p/flushcone-internal-clear/44988
https://www.NoLinkingToThis/p/flomasta-internal-flushcone/600fy
Need to make sure it’s not running down from high up first
Also need to make sure your flush pipe is the correct length eg not short
It is something
This is much appreciated! How much will it cost me to have it done you think?
Cost is a difficult one as rates are different in different areas but if you showed a local plumber that photo they'd know what they were dealing with and I would assume around an hour's labour and just a few pounds for a new seal. It's not a major job.
Reply to the thread, titled "toilet leaking" which is posted in Boiler Advice Forum on Plumbers Forums.
