C
caretaker
...Went into work this morning and found the bowl in the middle toilet of three bone dry with dry toilet paper in the bottom although there was water in it on friday and no one has used the toilet or adjacent ones since. Strange I thought but not half as strange as when a few minutes later I went to another run of toilets about 20 yds away and found exactly the same in another toilet also in a run. So a few things that are baffling me. If there was a blockage in the system how come the toilets either side were not affected. If the problem was caused by such and a syphon effect induced into the system surely this would only draw the water through until the upper level of the water reached the upper part of the U bend at which point the seal would be broken allowing the remaining water to flow back into the bowl. Both systems enter different manholes outside as well!!
Any suggestions gratefully received
