F
Flash Kincade
Hi all,
I have a problem with my toilet whereby it expels water into the pan after the flush has finished and cistern has refilled. It's a fair amount of water - lasts for as long and sounds as if somebody's having a pee.
There's no slow trickle afterwards, it just does it's thing and stops. This is after each flush.
I've had the flush unit out and all appears to be normal - no dirt/limescale or visible wear and tear. I've changed the rubber washers to be sure there's no problem there but it has not fixed the problem.
Below is a picture of what I'm rocking inside my cistern.
Thanks in advance,
Flash
Thanks in advance,
Flash
