T
Trisha88
I need help! 😕
I have bought a new toilet seat to replace a 31 yr old one!
The toilet bolt holes are 7.5 inch apart (centre to centre) and the new seat has a hinge with holes much closer togther rendering it useless. 🙁
I have 3 options:
1. Buy new seat (I've been looking online for one with adjustable hinges all day...so far nothing that will fit!)
2. Is there a way of putting different hinges on the new toilet so they align with my toilet bolt holes?
3. Worse case scenario I could buy a replacement hinges for my old toilet seat (the bolts and hinges broke into pieces when it was removed) and resuse that...but where can i get them (they use a rod system)?
Anyone want to throw my suggestions my way? I'd be VERY grateful! 😀
You can just buy hinges for some w/c's and alot are adjustable
But your best bet is for you to take you seat and hing to a good plumbers merchants,which there are many and I am sure they will be able to match you up
thank you. So far have tried several places and only one has hinges which are 7.5 inch apart....if anyone can recommend a place I'd be grateful
Hi Trisha88
Depending on what area you live in I find City Plumbing Supplies to be very reasonable for sanitary ware. You could also try the Plumbcentre although they may be a little more expensive.
Hope this helps
Steve
You will find that many of the Celmac range will fit older WC pans. I usually fit the Concerto, Sonata or the Calypso seat in this case. Plumb Center do these or can order them in.
If your existing seat is a Celmac seat you can actually buy replacement hinges but for the price of a new seat at under £20 it's not normally worth it.
This link tells you which seat fits which pan!
[DLMURL]http://www.celmac.co.uk/potteryfit.xls[/DLMURL]
Boiler Advice Forum
Deleted member 120897
