View the thread, titled "toilet seat" which is posted in Boiler Advice Forum on UK Plumbers Forums.
how does one change the toilet seat on one of these back to the wall pan and is it possible to pad lock a 3 geared griffter to a torbeck with the float removed ?
The seat comes with a kind of Rawl plug or toggle spring affair so its all done from the top. Dont drop anything down the hole though or you have to pull the pan out.
If you cant take the pan out (most are siliconed as well as screwed down) drill out the rod and bolt and use a toggle bolt to fix the seat down. Only takes about 10 minutes this way. Put some silicone on the hinge as a extra secure precaution. Taking the pan out means you're disturbing the flush pipe seal and cone and can open up a can of worms especially if there is a existing leak from there or the pan connector.
Alternativley, hammer a 3/4 dowl doen the rod hole with silicone and screw the hinge down with a long slim 2" screw.
Wall hung are worse!
eh, if there is a problem fix it silicone is a sealant not a cure all, putting a drill near the pan will end in tears
I rarely use silicone for much, but in situations like this it has its uses. Why not use a drill? Have done a great many this way for years without any problems. Use a HSS 1/4" drill bit with the drill set on slow speed and it will be just fine. Moreso if the rod is a plastic one not metal.
By the way you can drill right through a pan these days with ease. Our sponsors 365 drills will show you how.
good advice,, my old boss always told me never remove pan from cistern,wall etc, for the reasons you've stated and i totally agree,i like the toggle bolt idea...thanks
You can get seats with 'top fixing' hinges but they're a bit pricey (but good).
As for the Grifter question, lol, no. Not possible.
A Striker or a Boxer, yes! But not a grifter.
^^^Agreed^^^ Top fixing hinged seats are best for this.
Some fairly decent quality ones on BES for not a lot of cash (part numbers 14568 - 14571) - Available in white or black.
The "wellnuts" type of expanding bolt fixings are spot on too. P/N 17054. Cost about a fiver but save tons of time faffing around 🙂
Reply to the thread, titled "toilet seat" which is posted in Boiler Advice Forum on Plumbers Forums.
