Hi there. Forgive me, I am a total please moving noob....so I'm assuming the answer will be "call a plumber" but it's worth a try.
The shut off valve at the side of the toilet has started dripping. I had a look online and said first thing to try was turning the nut 1/8-1/4 and see if that stopped it. I initially thought it did, but it started dripping again. Through further discovery, I've (I think) worked out it isn't coming from the nut near the tap type part, but the nut on the right (I held it as straight and level as I could and the drip seemed to come from there. So the bit where the pipe connection and the nut meet.
I assume it's not as easy as 'just tighten the nut', but any advice? I'm pretty much a giant man child but after successfully replacing a waste pipe on a sink I just wondered if it was a possible repair for myself. Please see picture. There is another bit of pipe hidden on the right, it just moved when I took the picture. Thanks.
