View the thread, titled "Toilet waste small drip leak - plumbers mait not working" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Amateur here. My toilet waste has a small drip leak at the join, & I was advised to use Plumbers Mait to seal it up. I did, & it worked for a while, but what I find is the putty is continuing to get wet from the leak & the seal is being broken a few days after I press it in again. Is there some kind of sleeve I could put around this to try to fix this more permanently? Advice appreciated.
I think you have some kind of ribbed insert that isn't quite where it should be (or needs replacing) and I'm not quite sure what I'm looking at. The bit on the right is logically a painted pan connector, but almost looks like a bit of cast-iron in this photo. It seems to insert into a piece of uPVC soil pipe, but possibly someone has inserted the ribs into a socket which is slightly larger bore than the pipe itself and may not really work correctly.
I'm not a fan of Plumbers Mait being used for plumbing-related purposes, and used in conjunction with plastic pipe it isn't the right material anyway. I'd suggest taking it all apart, cleaning it up, reassembling with a bit of silicone grease (or water or soap, if you must) as lubricant, and possibly a new pan connector, but if that is your only toilet, do you really want to DIY it?
It's not that it's not possible to DIY such a thing, it's that once you have it apart, it may be a while while you work out what you need to get it back together again. And if there is anything upstream of that connection, make sure you have some way of stopping water coming out from other appliances. Something like this is handy:
You could try making a bandage with a strip of cloth smeared with silicone sealant to make a form of sticky tape. I suppose if you then smeared the cloth with silicone after it had set, you might even make it reasonably hygienic in that you would have a smooth, wipeable surface.
You could wrap it with insulation tape to make it wipeable (you might even be able to fix the leak with insulation tape if you are skilled and nothing is moving. Ditto for duct tape, but probably harder to use.
You can get self-amalgamating tape, but expensive in the quantities you'd need.
I've heard good things about Denso tape too.
Reply to the thread, titled "Toilet waste small drip leak - plumbers mait not working" which is posted in UK Plumbers Forums on Electricians Forums.
