Hoping you can help with a strange problem - I noticed floor tile grout lines near toilet bowl are getting damp - I dried with a hairdryer but the problem reoccurs within a few hours , even when toilet not flushed. I can’t see/feel any water leaking from waste pipe seal (behind WC) , from cistern, supply line or from fasteners that secure cistern to bowl.
I have attached a couple of photos , the toilet bowl is on the immediate right and the tiled wall is at the top of pics. I wondered if there may be a pipe leak behind tiled walls but I recall that the pipe run at that point has no joins so less likely to be leaking and also you will see in photo 1 the damp patch seems to creep from right to left (toilet outwards) rather than from top to bottom (from wall although that eventually gets damp too).
Any suggestions ? Planning to contact a plumber tomorrow and hoping this is a WC issue since that will be simpler than removing tiles .
Cheers
Cheers
