H
hardya
Hi I don't know if you can help me. I've looked at numerous videos but none of them seem to match my symptom.
The toilet wonte flush basically because the valve wonte open. when you pull the handle the metal hook pulls a kind of sall plunger all the way up to the top of a small tube but it doesn't seem to open the valve to flush the toilet. None of the videos seem to mention this tube thing. the handle doesn't seem to be adjustable, but as far as I can see it pulls the plunger thing all the way up to the top just like it used to.
I infer from the videos that we have a cyfon toilet. Most videos mention replacing flapper valve only for leaking which I don't have. One video doesn't mention the leaking but says the flapper valve will need replacing if it doesn't lift up so maybe it does need replacing, and they say you have to remove the entire cyfon to change the flapper valve, but they don't say how and it seems to be stuck fast.
Any help or advice greatly appreciated.
