J
Joe123
I've had a google around and don't seem to be able to find the solution for this toilet that won't stop running. It's bad timing too as I just had a meter installed! I'm really hoping someone here might be able to assist me as I can't really afford a call-out and a subsequent markup on any necessary parts.
Here is a photo - the filler thing is different in design to the ones I've found in online trouble-shooting articles...
Basically, the cistern fills up, and the rate of filling slows as usual as it gets to the top, but it just goes on filling at that slower rate, pouring down the overflow tube into the bowl.
The float (a grey plastic cup, you see) is rising and the mechanism on top (the circular grey bit) is changign angles - it's not jammed.
I took the circular grey bit off. On the underside is a small black runner bit, and on top of the white column that it covers there is a small hole. It appears to my untrained eye that the water is supposed to shut off when the grey bit changes angle, bringing the little rubber bit against the small hole. When I had the grey bit off, I tried covering the small hole with my thumb and it still didn't shut the water off... I don't know if that means the problem is with a sensor of some kind? Or maybe I'm theorising it all wrong.
Some help would be very much appreciated. The toilet was installed, all new, nearly 2 years ago. Maybe 9 months or so ago it did this, and I took it apart and fiddled with it for over an hour before losing patience with it and hitting it with a hammer... which seemed to work!
Thanks guys
Thanks guys
