A
andyg0507
hi all got a problem with a friends toilet cistern.
once the toilet is flushed(via push button on right) the cistern empties fine, once its reached the correct water level the outlet into cistern keeps flowing a little, if you push the float arm up it obviously stops.
ive changed the washers etcc.. and tried raising the water level a little to try and raise the float up to shut it off but no joy😕 any ideas.
