View the thread, titled "Tool list for Reactive maintenance Plumber." which is posted in Plumbing Tools on UK Plumbers Forums.
armyash
Subscribed
Not long until I start my new job, I have the majority of tools that I think I need but as I do a lot of different types of work I carry a lot of stuff that I won't be needing.
I'm going to get a new tool bag and get my hand tools sorted.
Hex Keys
Torx Keys
Adjustables
Grips
wire cutters
Long nose pliers - After an extra long set too but can't find any decent ones, recommendations?
Screwdrivers
Olive cutters
Pump spanner
Nail bar
Hammer
Chisel
Pipe cutters
Boat level
What else shall I carry?, that's not all i have by the way just going off what I've been using today.
Ash heads up mate, if they equip the same way bg do you'll receive a ladder, vac, lead light, multimeter etc if not I've found some cheap deals on fluke 116. I say cheap it's still over a ton but cheapest I can find a guaranteed genuine.
I'll also list my tool kit once I'm out of the shower and the sprogs are in bed.
+1 in the 116 its a great multi meter even has milly volts
I have a 2 day induction and then 2 days out with another engineer so hopefully that will allow me the chance to find out what's supplied and what isn't.
Stuff it kids nicked my bath!!
Pad saw
Wrecking knife
Pry bar
Hammer
Lump hammer
Stanley knife
Screwdrivers plain
Screwdrivers vde
Ratchet swivel head spammers 8-19mm
Allen key set
Compression spanner
Adjustables x2
Micro adjustable
Grips x2
Micro grips
Ratchet rad tail wrench
Standard rad tail key
Files round, flat, half round ******* cut
Poly cutters
Magnetic parts dish
Mini hacksaw
Hacksaw
Digital thermometer
Torch
Wire strippers
Bent nose pliers
Long nose pliers
10,15,22,28 pipe slice
32&40mm pipe slice (waste)
Tape measure
Levels boat, mid and large
Volt pen
Inspection mirror
Tap reseating tool
Stilsons various
Chain wrench
Pump key
Turkey baster
Jumbo sponge
Pressure gauge
Flow cup
Ratchet crimper (probably not needed)
Nail punch
Plus all power tools and accessories. And many more that I've forgotten or can't see without moving stuff
Pad saw
Wrecking knife
Pry bar
Hammer
Lump hammer
Stanley knife
Screwdrivers plain
Screwdrivers vde
Allen key set
Compression spanner
Adjustables x2
Micro adjustable
Grips x2
Micro grips
Poly cutters
Magnetic parts dish
Mini hacksaw
Hacksaw
Digital thermometer
Torch
Wire strippers
Bent nose pliers
Long nose pliers
Tape measure
Volt pen
Inspection mirror
Tap reseating tool
Stilsons various
Chain wrench
Pump key
Turkey baster
Jumbo sponge
Pressure gauge
Flow cup
Nail punch
Wow thanks!
I have some of that stuff but leaves me plenty to get too. I finish my current job next Tuesday and having the rest of the week off to sort my tools and admin myself, can start my new job fully prepared and make sure i have everything.
the trick with reactive maintainence is a smalll kit for first look and then a bucket to get what you need from the van half the jobs youll do with the small kit they probably want 10 jobs a day so most of the time its in make safe and order mats most companies now dont like you having any stock on the van
dust sheets and I also use rubber covered sheets to protect worktops etc, stubby screwdrivers, I'd be lost without my impact driver, to allow quick removal of cupboards and shelves hiding the boiler (cost extra to put them back 🙂 )
It will be interesting to see how they work. The first 4-6 weeks will be a nightmare i'm sure until i get in to the swing of things and get a system going. One of the girls in the office said minimum 8 jobs a day, the first week or so I might struggle to achieve that but then once I find my feet I should be ok.
You can def be over-tooled and over-stocked. 9 times out of 10 when you don't have the right tool or fitting you'll make do with something else. Don't spent your next month's wages on making sure you've got everything going.
For instance I haven't had an external stopcock key for about 6 months. Where there's a will..
Yup, you can do anything if your flooding the customers roof space and havent got a key to turn that bleeding valve off in the road, hence why i have one of each 🙂
Reply to the thread, titled "Tool list for Reactive maintenance Plumber." which is posted in Plumbing Tools on Plumbers Forums.
Thread starter
armyash
Subscribed
Joined
Location
Kent
Thread Information
Title
Prefix
N/A
Forum
Plumbing Tools
Start date
Last reply date
Unsolved
Thread Tags
armyash,
rocketmanbkk,
