Top tip for the day
View the thread, titled "Top tip for the day" which is posted in UK Plumbers Forums on UK Plumbers Forums.
gasmanrob
When soldering at height make sure you don't get splash solder in the eye
3 and a half hours in a&e to scrape the solder off of my eye, have a small abrasion and an eye pad to rest the eye
Had A bit of enamel from an old metal kitchen sink stuck in my eye a few years back that was painful but not as painful as your injury I suspect......hope it heals real quick for you Rob....regards Turnpin:furious3:
bloody hell rob your one very lucky lad,i have detached my retinas twice,once through being a typical teen,the other through slipping with a knipex but that could have been far more serious what you done get some eye shields asap
It was agony! Still managed to finish the cylinder fill it and wire the immersions before getting myself to hospital.... Now that's dedication
could have been a lot worse had it of been a bigger bit of solder very lucky indeed. No amount of eyewash was moving it either and trying not to panic. Will be re assessing that work method me thinks
thinking on it the normal shields might not have helped wrap arounds are good but am not fussed have these though seem ok
Dewalt - Protector Safety Glasses - Clear Lens - EN166.1.F - [SS-DPG54-1D]
I got a bit of tile in my eye the other week, my fault and luckily it washed out. Tret myself to a new set of safety glasses.
My tip of the day would be - don't park you van in the ditch!!
at least the new one I need to get next week will be tidy! for a while any way!!
My old apprentice stuck finger into a massive lump of pink foam it burst all over his face and eyes. He didn't like being sprayed in the eyes with acetone, but he can still see. I started to wear saftey specs at work now. Eyes worth too much. Couldn't stand not to beable to perv on women!
Had some brick dust blow back out of a hole in my face.
The little chunk cut into the inside of my eyelid scratching the crap outa my eye
Went and grabbed these laavly glasses, no gaps to go around either as they have a foam type material all the way around.
dont drive your landy flat out through heavily flooded lanes while having a *** with the window open,the cab was a mess
not being able to see means the specs protect you a bit, however I always seem to be in the local cottage hospital getting an eyewash, last for rust off the trailer fm not having the goggles on when I got the airline going, plonker mk 1!!!!
ouch i know how you feel on that one. I got a blob wet plaster in my eye when doing a ceiling and it took an hour to wash it all out. and i couldn't see out it properly for a month
get well soon dude
serviced a old ideal w wm today forgot that old balanced flue boilers have a tendancy to blow rust and shale in your eyes
The bolle ones are excellent. If you use head band they rated for sthil saw and grinder. We made them standard issue on a carillon job. Inspector went off on one with lad, yellow card till I pointed out we were actually being pro active as no one ever put goggles on as specs were ok
I love them, really great.
got these gloves too.
can handle pipes pretty much straight after soldering
Ansell ActivArmr Specialist Handling Plumbers Gloves Blue / Black Large | Performance Gloves | NoLinkingToThis
Had half a brick fall down a chimney when I was looking up. Ouch, concaved eye ball for two days until it popped back.
They look thicker than my super safe extra safe "council slags" johnnies? Can you feel anything?
Also kb what are you going to do when you have a mrs 3 kids and a £750,000 mortgage, no tools or toys for billy?
When the "talk" comes about kids i say im sterile..... Works a treat 😀
What happens then when she stops pill and no helmets in use...... Oh dear mini me has a mini mini me?
Have a friend a sparks. Lost an eye when standing behind another sparks while he drove a Hilti nail into a Wall. The nail flew and hit him in the Eye.
RE ROB. hi its hurdy hope you get well soon, time to start thinking saftey wear saftey glasses.will save all the grief. see ya soon hurdy.:86:
I once got a blob of flux in my eyes that fooking hurt bet yours was way worse , hope it clears up soon for you
Reply to the thread, titled "Top tip for the day" which is posted in UK Plumbers Forums on Plumbers Forums.
gasmanrob,
gasmanrob,
