View the thread, titled "Torrent cylindar with solar - Hot water has antifreeze" which is posted in Bathroom Advice on UK Plumbers Forums.
Have a client with a torrent cycildar with solar indirect. I changed some Radiators a few weeks ago now client says hot water smells of antifreeze ??
Solar system is pressured to 1.8 bar which I did not touch and pressure is still the same.
Central heating sealed system. I reset after new radiators and set back to 1.5 bar and still the same.
Anyone with any idea where I start to look or what I could have done when changing radiators. 😕
Ray..
If a coil (P. heating or solar) is leaking wouldn't the pressure be dropping. And how would the antifreeze or inhibitor get into the water. Is the mains water not sealed (coil) in the thermal store?
It's a thermal store with mains on a coil?
Could be a break in cold water coil then it could be the inhibitor he is smelling sounds like a new cylinder how old is cylinder
If it's a thermal store it could be the plate heat exchanger has corroded. Meaning the two will mix. This is quite common and not unusual for a 5 year old component.
Reply to the thread, titled "Torrent cylindar with solar - Hot water has antifreeze" which is posted in Bathroom Advice on Plumbers Forums.
