View the thread, titled "Towel rail valves leaking" which is posted in UK Plumbers Forums on UK Plumbers Forums.
R
ras
Good Morning all,
I need some advice on a leakage that I am having with my bathroom towel rail.
I have unscrewed the cap of the valve and tighten the nut underneath but still leaking. Please see the image attached showing where the leak is.
Does that mean I need to fit a new valve?
Thank you.
Ras.
Yes, it's a replacement. You can swap the internals. One of these below from screwfix will swap.
http://www.NoLinkingToThis/p/verona-angled-radiator-valves-15mm-pair/37800
Thanks Knappers and Chalked for the the replies.
I have a few questions if you don't mind.
1. Do I change both valves or just the one leaking?
2. How easy will it be for an above average diy guy to swap them?
There is a screwfix near me so can get those tomorrow.
3. Do I have to drain the towel rail before carrying this out? Any instructions in this direction will really be appreciated.
Thanks once again.
Ras.
Buy a better quality valve with a spindle gland rather than an o ring seal and you wont get that problem again
Reply to the thread, titled "Towel rail valves leaking" which is posted in UK Plumbers Forums on Plumbers Forums.
