J
Joon
I have TREVI 45 TWIN 3.b bar shower pump connected to a water tank and obviously flow water to shower booth. It worked fine for last 5 years until yesterday. Yesterday I had to drain all water out from the tank in order to replace a pipe valve in the kitchen.
Then I turned on the shower forgetting re-filling the water tank that I guess some air went into the shower pump. I turn off the shower node and re-filled the water tank but the shower pump doesn't kick-off at all from then.
I've replaced 'fuse' and turn off/on the shower pump power a few times but nothing happens. Does this mean the shower pump is completely dead? Or is air blockage (I presume) is stopping the kick-off? I literally got no water at all from shower tab now.
It would be really appreciated if anyone can advise me here. Thank you.
Tom,
Thanks you very much for the comment and apologies for my ignorance but as pump doesn't start at all, I don't think any water is flowing. What exactly do you recommend to check? If I take off the flexis - there are 4 (hot in-out/cold in-out), what exactly I should check?
Hot in and cold in
The pump starts up via flow switches which detect a small gravity flow of water then then turns the pump on. Removing the inlet flexis will allow you to see if there is a flow there. If not then trace the pipe back
Tom,
Thank you so much for this. When I turned on the knob, normally a bit of cold water came out from shower tap and then I can sense shower pump kicks off and hot water came out after. So I presume the cold water flow at first is what you've described as 'gravity flow of water' you mentioned above which triggers pump start.
At the moment, I don't get any water flow from shower tap even if I turn on the knob. Does this mean there is some blockage in the pipe between water tank and pump? Or the air either in pipe or pump can completely block the pipe? Or do you think it's more likely an electric circuit issue in the pump?
Could you please provide your thought on this?
All,
Thank you so much for your advices. I've checked the flow after taking off the flexis and indeed found no water in the pump. I've checked the connected pipe back and refilled it with water and turn the knob switch on which then kicked off the pump again. Million thanks to you!
Hi, I have the opposite problem. When we turn the shower off the pump keeps going...Any suggestions? We currently have to turn the power switch off, then back on when we need a shower...
