I've just specked one on a job with limited wall space. It's my first.
Get some 150mm concrete screws to fix it to wall then!
Almost essential on GSHP and ASHP rettofit installs; with the flow temperature down at 45° to get the same heat (kW) output you need 3.1 x the amount of radiator 🙂
Alternatives are fan assisted radiators - then you've to provide leccy power as well (ok in full refurb / new build)
Reply to the thread, titled "Triple rads" which is posted in UK Plumbers Forums on Electricians Forums.
