M
Malcz86
Hello,
I'm trying to replace a stuck thermostatic radiator valve on a radiator in a combi boiler system. The valve is stuck in the off position and I've closed the other valve.
I've looked at several advice pages online and a few youtube videos. I started by loosening the nut attaching the valve to the rad to drain the radiator expecting a lot of water to come out. But was just a few trickles. So then moved on to the nut on the pipe coming out of the floor. Now some of the advice I'd seen said that there may be a bit of water coming out here so had towels ready, but as I loosened the nut more and more water started spurting out until the several towels I had were soaked, so I stopped and tightened up again.
What did I do wrong?
I switched the central heating and the hot water to the off position before I started, should I have switched the combi off at the wall?
Should I have just kept loosening the nut and eventually the water would have stopped? obviously wasn't keen on trying this incase it didn't!
Or do I need to drain the entire system to change this one valve? I thought I should be able to do it with just draining the rad?
Any help or advise would be appreciated.
