View the thread, titled "turn basin tap on shower works" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
A
adrianfs1
hello guys.
hope someone can help me with this annoying problem.
went to a job, customer complained that her shower wont work, then said if she turn basin tap on shower works. Now, i have disconnected the feed and ran the water, no restrictions. reconnected turned water back on and the shower worked but only for a minute, then realised that the pressure light was on,on the shower, there has been no work carried out on the plumbing, and this fault has only just started, the shower is a mira sport,
was wandering if it could be a faulty pressure switch,works fine for a couple of mins when the pressure is dropped but dies off within 2-3 mins,
any suggestions much appreciated. Hope ive explained it ok.
hi Tom, would the solinoid valve cause the pressure drop, all power is on, and it sounds like it wants to work, as i said if you turn the shower off, open the whb tap then turn the shower back on, it works.......MAD
Reply to the thread, titled "turn basin tap on shower works" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
