View the thread, titled "ultracom rattle" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Glow Worm Ultracom 35 store.
Hi Everybody.
Hope someone can shed some light on this one, the above boiler rattles when you call for hot water or when it heats its storage up early morning, but it is ok when the heating is on, its quite lowd and vibrates through the pipework.
It does it almost immediately even before the burner has kicked in.
I have replaced the plate to plate, diverter valve and the pressure vessel over the last few monthes and this has started just in the last few weeks.
I have spoken to Glow Worm technical but not a lot of help, I suppose telephone diagnosis can be tricky.
If any one can help it would be most appreciated.
many thanks
Alan
Unless gas safe you can't take the cover off get a gas safe eng out
and really you shouldn't of replaced / cleaned the heat exchanger/ other parts
well actually I am gas safe registered so perfectly compitent to carry out above work.
Alan
That's fine as you can understand we can't discuss fixing gas appliances on an open forum, get your post count upto 10 and pm gas man (the mod) with your gas safe no and he will let you in to the reg installers part
As Shaun says mate. Hang around say a few hellos get your posts up and join us in the private gas forum and we can help you out
As above.
Reply to the thread, titled "ultracom rattle" which is posted in UK Plumbers Forums on Plumbers Forums.
