View the thread, titled "Unable to fit DIY pipes bought from Canada" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
M
masaw
Hi Guys,
I bought a bidet from Canada which can be fitted over the toilet stool. The problems is that the pipes that cAme with it, I found out later, are in north american measures.
The main problom is fitting the "Adapter" shown in the attached diagram and picture:-
between the 22 mm pipes under the washing basin.
Cold Water under basin 22 mm pipes.jpgPicture of British underbasin cold water pipe with a ruler.jpg
I would greatly appreciate help with this regards.
Best wishes
Matthew
Hi mathew,
Where in the country are you? Ther'll most likely be a merchants in your area who can help get the adaptors you need! Up here in Newcastle I'd be consulting a firm called Crosslings, Not sure if they're national or not?
Thanks diamondagas,
I'm in Kent, Whitstable. I have been to few merchants in an industrial park and they were unable to help me.
Maybe someone down your way will give you some advice mate 🙂 I supose you've checked out the manufacturers website for suppliers in UK? Gave them a call? Just a couple of obvious roads no doubt you've been down? 🙂
Why would you want this thing from Canada ? What do you mean it fits over stool ? do you mean it some how clips around wc bowl, This sounds totely illegal and you could leave yourself open to prosecution by local water board.
Reply to the thread, titled "Unable to fit DIY pipes bought from Canada" which is posted in DIY Plumbing Advice on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
DIY Plumbing Advice
Start date
Last reply date
Unsolved
masaw,
aqualogic7,
