Unable to remove lever on Methven sink mixer
View the thread, titled "Unable to remove lever on Methven sink mixer" which is posted in Bathroom Advice on UK Plumbers Forums.
Hi All,
I have a Methven mixer that is leaking around the base so I bought a Fixit-It repair kit.
It does not have a red/blue cover for access to the grub screw at the front but a little indent at the back.
I have tried using a 2.5mm allen key to remove the lever but cannot find the screw .
What am I doing wrong ?
It could well be a 2mm Allen or a slotted grubscrew.
Try taking a photo on your phone , which you can then zoom in - might need to provide a light source too.
Thanks for the reply. Used a mirror and torch and I can see the grub screw that is accessible at a 45 degree angle but for the life a me I can't get the allen key in when I use a 2/2.5mm key. What a stupid design.
Hiya, we're having a similar issue. Did you manage to do it and if so, how?
Thank you!
Reply to the thread, titled "Unable to remove lever on Methven sink mixer" which is posted in Bathroom Advice on Plumbers Forums.
tilba16,
tilba16,
