View the thread, titled "Underfloor heating thermostat prob" which is posted in UK Plumbers Forums on UK Plumbers Forums.
R
Raymundi
Hi, ive recently had underfloor heating installed and two of the zones are governed by a digital programmable thermostat, a Polypipe PB PZP. I have tried to turn the heating down from the makers pre set temp (21 degrees) but the temp still remains high and the unit constanly click (which indicates Heating Demand). I have followed the instructions to the word and dont know if the thermostat is broke or just not very good, any help and advice would be great.
A common mistake is that people tend to overtighten thermostat housings thinking this will prevent a leak. When this can actually cause a leak by warping the housing. A little black silicone on the gasket is also helpful.
_________________
Thermostat
Hi, thanks for the replys. Ive now got it sorted. The plumber had wired up the sensor for a wet room and this was confusing the thermostat, just had to disconnect two wires and hey presto. Cheers
Reply to the thread, titled "Underfloor heating thermostat prob" which is posted in UK Plumbers Forums on Electricians Forums.
