Underfloor heating
View the thread, titled "Underfloor heating" which is posted in Central Heating Forum on UK Plumbers Forums.
Just having a bit of trouble with one room underfloor heating.
New build bungalow in 2016 with a Daikin Air Source heat pump.
No idea what make the manifold is for our underfloor but for no apparent reason the bathroom will not come up to temperature. Being "older" we have always kept it ay 23ºC.
Ever since we moved in the pressure in the Daikin loop (from the Daikin indoor unit in the garage to the hot water tank in the airing cupboard) has slowly dropped off over a couple of weeks. Three weeks ago I found what I thought was the cause, a leaking joint just above the airing cupboard ceiling.
Daikin came a repaired it, which necessitated drain the system about a foot so the pipe could be cut. Circuit refilled and everything OK EXCEPT the bathroom will no longer go above 20ºC. I've tried adjusting the flow from minimum to max but it makes no difference.
Any suggestions please, pic of manifold......
I have since learnt that this is a omnie (timoleon) manifold! I have written to them to see if they have any suggestions as to why just one circuit won't go up in temperature.
Reply to the thread, titled "Underfloor heating" which is posted in Central Heating Forum on Plumbers Forums.
cheddarman,
cheddarman,
