J
jstephens
Hi everyone,
I'm a sparky so my plumbing knowledge is limited.
I was asked to go out to a new underfloor heating system last week as the last 2 sparkys apparently couldnt get it working.
Its a baxi combi boiler with rads upstairs and underfloor downstairs.
the rads are controlled via a honeywell wireless stat.
The underfloor looks to me a basic set up, its not a manifold just one zone and i might be wrong here but a mixing valve with a pump next to it.
The underfloor again has its own wireless stat.
The problem they are having is whichever stat is called it all comes on together, no separation at all.
The is a 2 port valve (not connected) on the flow going to the rads upstairs.
now obviously at the moment its not going to separate as the valve hasnt even been wired.
Whats confusing me is there is only 1 valve for the rads and nothing for the underfloor. from what i can see the flow going from boiler has a tee which also flows to the underfloor, surely there should be a valve there too?
sorry for lack of knowledge on the plumbing side but i can't see much point wiring it correctly if it needs 2 valves.
cheers, Jon
cheers, Jon
