View the thread, titled "Unvented Cylinder" which is posted in UK Plumbers Forums on UK Plumbers Forums.
O
ozzy
Hi all hope you have all had a good Christmas and new year.
I have a customer with water running through the tundish. The PRV has been replaced but the water still runs through. The water is not hot so I don't believe its from the TPRV. The cylinder has a expansion vessel screwed in to the top. I checked the pressure and there was no reading. I pumped it up but the water is still going through the dish and the pressure has gone down. Could the vessel be the problem and needs replacing ? I do have a ticket for unvented as there are more of them about now but I haven't done many and would like your advice and help.
I had something similar not so long ago, replaced the expansion vessel, the T&PRV but still had water running through the tundish. In the end I discovered a shower valve was allowing cold to feed back through the hot pipe work into the cylinder and then discharging. Ensure all mixer taps and shower valves have non return valves and the problem should go away
It could still be the vessel. If it's losing its charge it's also losing the volume required for expansion.
Thanks everyone for your help with this, its all sorted. The expansion vessel was shot and losing pressure and discharging back through the PRV. It had cut a grove in the seating and still ran after the vessel. Found the TPRV was not opening so its had a good service. New vessel, T&PRV. Thanks again.
Reply to the thread, titled "Unvented Cylinder" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread Information
Title
Unvented Cylinder
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
ozzy,
ShaunCorbs,
