J
jase158
Got called to a customers house the other day as cylinder was leaking from overflow,
Turns out that the cylinder is an unvented cylinder but I have never seen one like it before,
It was copper cylinder made by gledhill, there was no expansion vessel or PRV, it said on the cylinder that the above tank was an expansion chamber, the cold inlet was teed into side of cylinder and then into expansion chamber with a float valve on the inside. It also said that the expansion chamber acted as a expansion vessel.
It isn't a tank on the top as there was no outlet to the main cylinder.
my question is how does this work? if the float valve is shut then it is shut, nothing you can do to open it, even if the water is hot? or am i wronge?
also what could be the cause of the dripping from the overflow, I checked float valve, no leaks, replaced the immersion heater thermostats as they were very old and had no resets on them. only thing was, when i read instructions, they said 11" immersion heaters, when I got 7" thermostats to go in, they were smaller then what was in there. so I guess they wont work properly.
any ideas please?
any ideas please?
