Out of curiosity how many days labour do you think it would be to replace a vented copper cylinder with an unvented one? Both are indirect cylinders and all the required pipes are of course already in the airing cupboard.
Tip for learning for exam would be to download a manufacturer's instructions and learn the diagram from stop tap to cylinder to discharge pipes and hot water outlet.
3-4hrs plus D2 pipe, (which can be anywhere from 0.5-4hrs as well depending on route and position of cylinder in relation to external wall or waste stack)
Having read this thread I completely agree that the unvented course is easy to pass and gain a qualification, but what does worry me is the amount of self certified cylinders that I go to where the installer has clearly not followed the MIs and completely forgotten how dangerous unvented can be, for example PRV and PTRV facing upwards or not connected to regs, Expansion vessels installed in the wrong place, for example I have seen them installed onto the balance pipe outlet on the group set, installed the wrong side of the group set and in some cases not installed at all, Lever valves installed onto the outlet of the cylinder. I could go on but you get the idea,
I feel a lot of these courses are not fit for purpose, they are fine for attaining a qualification but is a one day course enough to teach anyone the true dangers of an unvented bomb
Reply to the thread, titled "Unvented Hot Water Course" which is posted in Plumbing Courses on Plumbers Forums.
