Ok, I've posted something about this before but I'm still not sure about it... So....
To test the stat, I put my meter in the two small brass holes next to the neutral wire??? Which set on continuity should be zero when the stat is set to minimum (or temp satisfied) and a reading if set to high (or temp is not satisfied).
To test the element I do as I would with a standard immersion.. Take off the neutral and measure ohms which should be between 18-20..
Only, I tested two today (not the same ones as the pic) and I was getting 6 ohms but the element worked fine.
I just want to know WTF is going on!!!?????
Am I doing something wrong here???
