Thanks guys. So I don’t have to put down anything on the paperwork except to document it.
I thought I might have to put down, not to current water regs or something like that.
Thanks again
Huw
I never understood the reason for the 600mm measurementIt is 600mm from the T&P not so bad if the D1 from the Pressure Relief is a bit longer.
I list and say that it doesn't comply the Building Reg's G3 & MI's.
Additional frictional resistance going over that length would effect the kW / discharge rating of the T&P under high temp discharge, I believe.I never understood the reason for the 600mm measurement
Reply to the thread, titled "Unvented pipe work" which is posted in Gaining Plumbing Experience on Electricians Forums.
