View the thread, titled "Unvented santon (45 yr old?) immersion heater with gravity fed tank?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hello,
I hope someone can help, we recently were forced to move to a ground floor social housing flat because of my partners worsening health condition. It has an assisted shower with a mira advanced thermostatic low-pressure shower unit so hot water for baths isn't a problem.
However, the immersion heater fitted is apparently as old as the building (45 years) and has as far as I'm aware never properly been serviced. I can see some minor fixes probably installed with the new kitchen in 2013 however it's in a right state and the Housing Association say that they will be installing gas in the block of 12 flats sometime...in next year or decade?!?!
We've literally only just moved in and it was boiling so bad that I was scared to even open the door to it, could hear steam and a huge amount of banging as we accidentally had it only for maybe a max of 4 hours? turned it off and no watch it carefully, I can feel the fused switch getting stupidly hot when turning it off and on almost to the point I need insulated gloves to turn it off.
Maintenance has already come around and found both stats at the max when supposed to be 45 degrees but even with them turned down only 3 hours on and it's crazy hot, we've had it off 4 days and the water is as hot as the kettle.
I've attached some pictures, to me someone who's not a plumber and I refuse to even tinker with it seems dangerous. And The water pressure is stupidly low anyways and we don't have a bath. I don't understand why a simple inline water heater wouldn't do the same job better?
tbh its old surprised its still in use, the only thing you can do is keep complaining
it wants ripping out and starting again
Not sure to who at the moment, they say they've done one property last year with gas but jesus Christ it's nearly twice as old as me.
It's a shambles really the housing assoation has alrssdy said we're over a month I arrears because the day we said we were interested was the day we signed up even after notifying them of a current private contract and letting them take the money out of our account.
Is there any chance the local council environment team would say this isn't fit for purpose?
Just concentrate on getting the hot water system in a usable and safe condition, if the water is still too hot then the stat/element maybe faulty or require further adjustment.
I have tried I only need a bit of hot water for dishes. We don't have much money far far under the poverty line atm and our last months bill at New place with brand new heating and solar panels was £196.
I'm not sure it just leaving it off is an option, is it possible to isolate the heater at the fuse boxes?
£196 is a heck of a bill, can't you just turn it off with the switch in the last photo you posted?
That was at previous property sadly with brand new economy 10 wet central heating and solar panels.
I'm too scared to take the reading of this place probably a reason everyone keeps moving out of this place
Leave it off, turn it on for 2o minutes` at a time and see if it's enough.
My concern was that it is still crazy hot after four days of being off and there seems to be some blackening on the cylinder above the heating element indicating it may be near to failing. Call them back if it seems dangerously hot if only to adjust the stat again, the header tank looks like it's been renewed but nothing else does.
Ah...just seen the immersion at the base of the cylinder. Surprised you can turn both on at the same time so you must have a dedicated circut and therefore fuse at the board. Ok from now on just use the middle immersion which appears to be connected left switch (Check) unless you need a lot of hot water. Half a tank should be enough for most of your needs.
Sorry got wrong end of stick thought the £196 was your bill for a month of electric at your new place.
If you only need some hot water for dishes, then just boil a kettle and mix it with cold water in a basin in your kitchen sink. Cheaper that way because you only heat the water you use.
Didn't even think of that to be fair lol, don't drink tea or coffee so never use the kettle lol
Thanks for responses guys much appreciated
You spoken to the council?
Costs me a fortune running my immersion heater, electric showers and just boil the kettle whenever you need hot water.
Reply to the thread, titled "Unvented santon (45 yr old?) immersion heater with gravity fed tank?" which is posted in UK Plumbers Forums on Electricians Forums.
