anybody got a unvented checklist/ cert that they have made i can have a copy of? otherwise ill have to mek one myself on a spread shee which is gunna pizz me off cus drinking vodka and i cant spewl good when im not dunk.
You've trained someone?? God help us 🙂
mind you, he must be in his sixties now, so he'll be retired soon 🙂
you cheecky git 🙂
i had my first apprentice when i was 19, had quite a few working at my old firm, all but one turned into a good fitter. The one that did not do well is under my patio, they get more annoying the older you get.
im still down wiv da kids tho, ive got a hoodie, i listen to house music, im cool??
I'm also a cool cat
Never heard of All saints tho, are they a bit like matalan because they rock.
my mate sid was in charge of socks at my local matalan. His nickname is still Matalan Sid, hes one of my home boyz. I could get some good deals on wilson sports socks back in the day.
Tprv
Prv
Strip and clean multi
Check for leaks
Assess D1 and D2
2 port and controls
Expansion pressure
Blending valve
Secondary circ
Immersion
Re set bubble if she's a bubble top.
I Have 52 pairs of the plumb center thermal ones . One for each week!
Pretty sure it's the same situation as oil, required to install and be able to self certify the install but no requirement to maintain or work on. It's not enforceable and unless something goes wrong no one cares.
I've made one myself now, with the help of a few members giving good advise/examples.
Most manufacturers require annual safety inspection.
Says so in their literature.
I took pics of mi's showed to lettings agency, explained that if the landlords didnt spring for the service and a leak damaged tenants gear then a claim would likely result. They sent letters out to landlords with uv's.
I now service check and certify twenty odd cylindrrs at 70 quid a pop
Yeh but normally thrown in, pump and valves ontop of each other and d2 is way out. Hope your a different animal on price work
Honest . Made me giggle! When you say your works rough it's generally not !
Reply to the thread, titled "Unvented service/maint checklist" which is posted in UK Plumbers Forums on Plumbers Forums.
