Hi. Im new so please bear with me. I will try to explain in as much detail as I can. I have a fairly large 3 bed house. We have a standard gas boiler downstairs (not combi) with an unvented water system upstairs. We have the main water tank with the red expansion vessel which is located just above it.
When the boiler kicks in in the morning to heat the water up, after about 10-15 minutes, water starts dripping into the tun dish where the pipe then runs out side. Also, while the water is heating up, the hot water taps feel as if they have a LOT of resistance behind them: when you initially use the hot water tap a big surge of water them it calms down. When the hot water is used for the first time after its started heating up, there is a noise which sounds like escaping air, which comes from the hot water cylinder area. Im not sure exactly where it comes from.
Previously, when we had a similar fault before, our gas engineer drained the system, re-filled it and reset the air bubble in the tank. This was fine for about 7-8 months untill it happen again. A new engineer done the same and it lastest for about another 4-5 months and it has gone again.
The latest engineer we've had out was here for about 10 minutes, didnt even touch the system and said he would order a new safety valve (the valve closest to the expansion vessel, there are 3 on the system). Im not a qualified plumber, but personally i think he may be wrong. Surely, if the valve was faulty it WOULDNT let any water out? And if it was faulty in the way of it staying open, there wouldnt be any pressure behind the hot water?
Any advise would be greatly appreciated!
Thanks!
Thanks!
