View the thread, titled "upgrading / addition of Nest to heating system" which is posted in Central Heating Forum on UK Plumbers Forums.
Hi I'm have a new central heating system New boiler / pressurized Cylinder 210 new mdpe main 25 mm its being done soonish ( plumbers busy at the mo )
how much more effort is needed to add a nest system or similar and what is entailed ? do you need new rad valves sensors etc. and could it be added retrospect or needs to be thought about whilst fitting new system
Ps old system was / is a Gravity fed one 50 Gallon tank and Copper cylinder which is going
Cheers
I'm not a fan of the nest these days.
If boiler has 'BUS' or 'opentherm' control option then I would look at using that,
Either manufacturers own control (depending on brand) or perhaps look at tado?
Nest does work with Open therm, it’s whether the boiler supports it.
Reply to the thread, titled "upgrading / addition of Nest to heating system" which is posted in Central Heating Forum on Plumbers Forums.
