Guest viewing limit reached
Uponor 16mm pipe
View the thread, titled "Uponor 16mm pipe" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
mikeyc
Got a cold main in this Uponor 16mm pipe that I need to connect onto.
Been told by someone you can get a compression adaptor to copper, but I thought every joint was crimped. Anyone know if that's the case or how the he'll I can connect onto it without having to buy the crimpers ect.
cheers
Any plumb Center will get you one in. It replaces a 15mm compression fitting nut.
Theses are what you need, quote the code for 16mm
Thanks for this mate, did the job perfectly.
When i quoted i assumed it was speed fit. Eas shocked when i cut it and found it was Uponor 16mm, especially when i googled and saw the price of the crimpers and fittings!!
T.hink i paid a few quid each and no special tool needed
Reply to the thread, titled "Uponor 16mm pipe" which is posted in UK Plumbers Forums on Plumbers Forums.
mikeyc,
mikeyc,
