View the thread, titled "Upstairs downstairs zones" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Bibfrey
Hi.
I'm not a plumber but am fitting a new combi into my house with my old man who is a plumber, but he's what I'll politely describe as 'old school'.
The upstairs and downstairs rads do currently run off seperate circuits and I'd like to be able to run two thermostats to allow downstairs and upstairs to be on at different times or at different temps. I'm also planning on getting nest or hive, does anyone have any advice on how we could easily create the two zones, if possible?
thanks in advance
adam
if an area is bigger than 150sq will require its own zone but tbh its your house so you can do what you want within the rules
and have a look at honeywell evohome
Just to clarify. If you have a house with upstairs and downstairs then a floor plan area of over 75 square metres would require 2 heating zones.
Thanks all, the s plan looks quite logical. Would this be a case of zones on / off or would it allow for both to be on but operating at different temperatures?
I'll take a look at the Honeywell, assuming it's similar to nest or hive, I believe I'm right in saying you'd have to buy two devices to cover the two zones?
Im not certain of the square meters for our house to be honest, it's a generous 3 bed semi running 10 rads.
Adam
He is yeah, he's still active but tends to prefer working on old systems ...... He's an expert with 30 year old glow worm systems 🙂
His knowledge really only tends to stop when I talk to him about wifi powered thermostats and valves.
Reply to the thread, titled "Upstairs downstairs zones" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
