Guest viewing limit reached
upstairs radiator furthest away is only warm ?
View the thread, titled "upstairs radiator furthest away is only warm ?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
H
hamster88
Hi can someone give me some advice, all the radiator in my house get very hot except one, which is only warm.
I have tried bleeding the air out, and it is still only warm. It is the furthest one away from the pump.
thanks
its an old central heating system. when balancing do i turn the valve going in or out ? Do i leave the hot water in valve fully open but adjust using the cold water valve going out.
Reply to the thread, titled "upstairs radiator furthest away is only warm ?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
hamster88,
dancinplumba,
