was wondering if it was possible to close flow and return to a combi then drain down to still use hot water. read some previous posts where the suggestion was to fit a loop between flow and return.
what purpose would the loop serve? would it not work to just close the flow and return prior to draining to maintain pressure in the boiler?
If an open loop would be needed for some reason, how will that correspond to new requirements for zoning?
