U
UserNameIsTaken
Vaillant 242/1 E - Hot water only lasts for about 10 minutes
Any ideas what is wrong with it? Getting frustrated in the shower, when the hot water cuts out after 10 minutes or so (sometimes after 5 minutes, sometimes not at all). To get it hot again I have to turn it off, wait a few minutes, then turn it on again and usually it will work again.
It appears to stop if the pressure fluctuates a bit. I can recreate it by running hot tap (hot water ok at this point), turning it off, then on again straight away. The boiler just does not kick in again.
Other info:
Boiler at least 12 years old (I think)
June 2012 - pump replaced (2nd hand)
April 2013 - Diverter valve unit replaced (new)
There is a caleffi pressure reducing valve on the inlet pipe too. Been there for about three years. (this one has no guage - 3 bar printed on top)
Thanks in advance for the help!
Does the boiler actually cut out or does it continue running whilst the water goes cold??
A GSR Engineer should check pressures max/min and check resistances on sensor(s) - unfortunately I haven't them to hand.
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. http://www.ukplumbersforums.co.uk/im...-gas-engineer/
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - http://www.ukplumbersforums.co.uk/users/8668/ or Redsaw - http://www.ukplumbersforums.co.uk/users/2718/ who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competetence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
