View the thread, titled "Vaillant Boiler losing pressure" which is posted in Boiler Advice Forum on UK Plumbers Forums.
byrnem10
My water pressure keeps dropping. I have topped up the water but still happening
Check all the rad valves to start off with, how quickly are you loosing pressure?
Check all the obvious fist.
Check all visual fittings, check pipe outside from pressure relief valve.
Not necessary a leak as said above, it may be a faulty PRV or Expansion vessel lost its charge.
Reply to the thread, titled "Vaillant Boiler losing pressure" which is posted in Boiler Advice Forum on Plumbers Forums.
