View the thread, titled "Vaillant combi problem" which is posted in UK Plumbers Forums on UK Plumbers Forums.
K
kiwi
[h=5]ok guys i have a vaillant turbomax plus 828 E combi, hot water for about a minute then cold, magnaclean twin tech on system but no spanner to remove bowl and it looks like someone has used boss white on it to seal the bowl and i have tried to remove it all to no avail, so removed entire unit and cleaned it best i could under a running tap and got loads out of it, removed plate heat exchanger there didnt seem to be alot of debris, but i replaced it with a refurbished one anyway, put back together ran heating system for about 10 minutes everything working fine including hot water, but today 3 days later back to no hot water ?? Question ..flow switch ?? or system full of crap and main heat exchanger in need of clean ???[/h]
you will have to give your Gas Safe number and apply to the GSR only forum mate; no one will give you advise on this issue. P.S Please tell me you are a registered engineer as if you bugger this up it does and potentially will have lethal concequences
Reply to the thread, titled "Vaillant combi problem" which is posted in UK Plumbers Forums on Electricians Forums.
