View the thread, titled "Vaillant EcoTec 831 intermittant noise" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Deleted member 32524
Hello,
Thanks for looking. Got called to above to a report of it making a noise, intermittently, no fault codes. Checked CO2 levels and it was at 8.5%, put it to 9.0% as per MI. Thought that would cure it, but no. Had a call today to say its back. I have not heard a peep? Runs smoothly when I was there.
Any thoughts before I go back? Thank you. Duncan.
I put screwdriver on pump it when I was there and it sounded smooth. What you thinking on diverter? Passing or maybe getting a stray signal?
May just be muck in the system but I have heard of intermittent noisy pumps and diverter on here before.
Sounds like I may have to stand at it till it does it, but probably a waste of time.
If it is like a trombone that increases and then fades, it is to do with combustion.
You will obviously need to hear it yourself though.
I have had a few that do it over the years.
Have you tried running on P1? when you are there?
I have not been able to hear it. Analyser readings were from memory 0.0009, co 101, co2 9.o, defo 9.o Combustion seems ok. I have not had burner out though. Not been on p1.
Its like going to the docs to describe pain.., you have to know what sort of noise it is , lol
Get the customer to video it perhaps
Reply to the thread, titled "Vaillant EcoTec 831 intermittant noise" which is posted in UK Plumbers Forums on Plumbers Forums.
